TwinTurbo.NET: Nissan 300ZX forum - Oil in exhaust manifold from ex valve seals?
Subject Oil in exhaust manifold from ex valve seals?
Posted by qcsolo on April 28, 2013 at 11:01 AM
  This message has been viewed 231 times.
Message Compression over 160 all cylinders so can't be piston rings, head intake valves are free of oil when checked with a camera passed through opened throttles and transfer tube plenum holes.
I don't think it shall come form heah gasket so I will remove exhaust manifold and guess that I will find out oil in the exhaust valves cylinder 6 which spark plug had oil on tip...the 4 one tip was black color but dry...
The pain in a neck job is to open all front of engine to remove sprocket, cam and timing belt.
Anyone used to have same problem and know a trick to save labor time? Like TUFOIL or anything similar in the engine oil that will boost the valve seal material size ?
I used to hear many years ago that automatic transmission oil had this boost effect on rubber seals...
Thanks
