TwinTurbo.NET: Nissan 300ZX forum - If the clamp on the right is loose enough
RoidRage76
on April 28, 2013 at 10:52 AM
Thank you very much gentlemen
posted by cHiNgLeZ
on April 23, 2013 at 05:55 PM
You might be able to make a hook from a coat hanger and spin the clamp to a spot where you can reach the screw. I did that with mine and used a screwdriver with a flexible shaft to tighten it. Saved me several hours of work.
Fuel Leak Under Throttle Cable Cover
cHiNgLeZ
00:24:20 04/22/13
That hose is known as the bastard hose
ttsmokin
00:47:10 04/22/13
Agreed... common issue. (and a nasty job, but do-able) (n/m)
Medallion Man
02:52:06 04/22/13
Re: Fuel Leak Under Throttle Cable Cover
ZTom
13:09:00 04/22/13
Tom, I'm not sure you've understood or are making yourself
Medallion Man
14:38:45 04/22/13
you will have to register to view... this:
Medallion Man
14:53:50 04/22/13
Re: you will have to register to view... this:
ZTom
16:44:55 04/22/13
Don't need to do it this harder way - see this write-up...
jzack
17:52:05 04/22/13
cHiNgLeZ
17:55:30 04/23/13
If the clamp on the right is loose enough -
RoidRage76
10:52:33 04/28/13
