TwinTurbo.NET: Nissan 300ZX forum - Yes, a mechanical gauge is a must!
Subject Yes, a mechanical gauge is a must!
Posted by OverZealous (CT) on April 28, 2013 at 12:16 AM
  This message has been viewed 218 times.
In Reply To Use a mechanical gauge posted by njz on April 26, 2013 at 07:17 PM
Message I'm pretty smart on the oil pressure system and have still been fooled by the electrical gauge and associated system. There's a reason the FSM expects you to use a mechanical back up. Ideally the mechanical gauge is connected to the oil pressure sensor location via a hosed connection... to avoid errors due to engine vibration. That's probably not necessary if you're simply doing a go/no-go test. Be careful and stay safe while trying to read the gauge with the engine running!
None of your work should have affected the oil system. It's very likely you don't have an issue.
OverZealous (CT)
My General posts (click)
My Technical posts (click)
