TwinTurbo.NET: Nissan 300ZX forum - Low oil pressure need help please>>>
Subject Low oil pressure need help please>>>
Posted by LocoZ on April 26, 2013 at 6:49 PM
  This message has been viewed 219 times.
Message I'm reading low oil pressure. I've replaced the oil pressure sending unit and harness. It got a little better, its now reading 15 psi at idle and 25 psi under acceleration. I know some people say that is normal but I believe it used to read approx. 45-55 psi under acceleration. I started to notice the lower psi readings after I replaced rear main seal, rear oil pan seal and rear retainer gasket. Do you think that had anything to do with it? Any help is much appreciated Thank you in advance!
