TwinTurbo.NET: Nissan 300ZX forum - Check timing belt is on correctly, try using a charger
Subject Check timing belt is on correctly, try using a charger
Posted by ttsmokin on April 23, 2013 at 12:03 AM
  This message has been viewed 216 times.
In Reply To Re: Did you hook up a battery charger? posted by longlivetheZ on April 22, 2013 at 07:06 PM
Message If everything else checks out, try adding a teaspoon of oil to each cyl and re-test. If compression jumps up, the rings/cylinders are worn.
