TwinTurbo.NET: Nissan 300ZX forum - Tom, I'm not sure you've understood or are making yourself
Subject Tom, I'm not sure you've understood or are making yourself
Posted by Medallion Man on April 22, 2013 at 2:38 PM
  This message has been viewed 287 times.
In Reply To Re: Fuel Leak Under Throttle Cable Cover posted by ZTom on April 22, 2013 at 01:09 PM
Message yourself clear....
the job can be done with only the removal of the throttle cable (plastic cover).
I'm sure there's a write up about it somewhere.
If replacing the hose doesn't fix it then yes you may have to replace the fuel rail... but that requires the removal of the top plenum chamber and not the lower one.
see the first reply.
