TwinTurbo.NET: Nissan 300ZX forum - That hose is known as the bastard hose
Subject That hose is known as the bastard hose
Posted by ttsmokin on April 22, 2013 at 12:47 AM
  This message has been viewed 635 times.
In Reply To Fuel Leak Under Throttle Cable Cover posted by cHiNgLeZ on April 22, 2013 at 12:24 AM
Message You can replace fuel line with fuel-injection (aka high pressure) rated fuel line 5/16" or go with Nissan OEM fuel line. Don't use the crappy auto parts store clamps either, OEM ones work great. If the little Phillips screw strips, you can replace them with small Allen bolts.
You will have to remove the plenum if you can't reach the fuel line, or twist it with pliers so you can access the screw.
