TwinTurbo.NET: Nissan 300ZX forum - Low readings by the 2nd cyl tested is terrible, bad batt or
Subject Low readings by the 2nd cyl tested is terrible, bad batt or
Posted by ttsmokin on April 21, 2013 at 6:53 PM
  This message has been viewed 193 times.
In Reply To Did you hook up a battery charger? posted by Tanley on April 21, 2013 at 06:21 PM
Message you are cranking way too long per cylinder.
It should be effortless to turn an engine over with all of the plugs out besides the one with the compression tester in it.
