TwinTurbo.NET: Nissan 300ZX forum - Re: no oil pressure
Subject Re: no oil pressure
Posted by Xteam300TT (South Tx ) on April 21, 2013 at 10:25 AM
  This message has been viewed 162 times.
In Reply To no oil pressure posted by jdavey11 on April 20, 2013 at 06:52 PM
Message Check the bottom of the pan for dents . A lot of replacement engines have been sat on the pan causing it to be pushed in against the oil pick up tube . This will restrict the oil from being picked up . If it is pushed in it can be addressed without pulling the engine . If the pan is fine did you prime the oil pump ? Check it with a second gauge / sending unit .
