TwinTurbo.NET: Nissan 300ZX forum - Trace back the controller wiring - power and
Subject Trace back the controller wiring - power and
Posted by jzack on April 20, 2013 at 10:44 PM
  This message has been viewed 210 times.
In Reply To Re: Using a meter and the car's electrical diagram, verify posted by ariz on April 20, 2013 at 05:39 PM
Message ECU signal. Doubt it's the wiring between the pump and controller since you were able to make the pump work using that same wiring...
Could be an ignition key switch issue too - could try doing a switch jump bypass to see if that helps?
