TwinTurbo.NET: Nissan 300ZX forum - try the cranking process three times for ~2s each time.
Subject try the cranking process three times for ~2s each time.
Posted by Ash's Z on April 17, 2013 at 3:51 AM
  This message has been viewed 206 times.
In Reply To ?, what would cause the car not fire when you are cranking posted by genic on April 16, 2013 at 10:52 PM
Message Pull the fuel damper vacuum hose loose from the balance tube and inspect for liquid fuel. If you have liquid in it, you've found the problem.....
If that's not the problem have you checked your fuel pressure during cranking? Does it bleed off to zero within minutes or less when you turn the keys off?
Ohm the injectors?
Pressurized intake tract leak check?
Check ECU for codes?
Enthusiasts soon understand each other. --W. Irving.
Are you an enthusiast?
If you are out to describe the truth, leave elegance to the
tailor.
Albert Einstein
