TwinTurbo.NET: Nissan 300ZX forum - Regarding spongy pedal when the abs bleeders were skipped...
Subject Regarding spongy pedal when the abs bleeders were skipped...
Posted by USCZ on April 16, 2013 at 11:56 AM
  This message has been viewed 269 times.
In Reply To Same, new hybrid vehicles on the other hand.. posted by ttsmokin on April 15, 2013 at 08:07 PM
Message I didn't skip or forget the ABS on two complete passes through the brake bleeding sequence. However, if the battery doesn't need to be disconnected, maybe it is just common to get trapped air in the ABS and it takes some time to work it out/up. All I know is that when I disconnected the battery (30+ minutes) and re-bled the front/rear ABS actuators, my firm pedal returned.
There was a week of time and few test drives between initial bleeding with spongy pedal and when I disconnected the battery/rebled ABS. Maybe this timeframe and test drives moved any trapped air in the ABS to where I could bled it out. Dunno.
