| Subject |
Re: Did you ever address the oil leak? |
| Posted by |
ZBOOSTT on April 12, 2013 at 9:51 AM |
This message has been viewed 346 times. |
| In Reply To |
Did you ever address the oil leak? posted by Nate (NoVA) on April 12, 2013 at 09:37 AM |
| Message |
Yep, Replaced the oil pump and all other surounding components. I've decided to just get another Z1 chip and now I can plug it in and compare. It's inexpensive and I can't see how it would hurt to try. I would be very shocked if it ran worse. I just can't get over the knock at only 3000 rmp, and feels sluggish until my boost pressure gets over 10psi. I hope the new chip gets it going again. I have no voltage issues, no vac or boost leaks...confirmed, timing is right at 15, the throttle linkage was done by SZ, so I'm sure that's fine. Idles smooth as silk. No smoke. No oil in the coolant or coolant in oil. Nothing off on the Conzult. It all started after my tune, and since it was not a complete tune, that's all I can think of. I'll post up when I receve the chip.
| Follow Ups |
Post a Followup |
