TwinTurbo.NET: Nissan 300ZX forum - Here's some thoughts: Starting power is more than having
Subject Here's some thoughts: Starting power is more than having
Posted by zellamay on April 12, 2013 at 12:45 AM
  This message has been viewed 357 times.
In Reply To Just click, no Cranking/no Starting problem. posted by Hawre on April 11, 2013 at 06:46 PM
Message 12v. You also need enough amps. A new battery should be good, but that really sounds like an electric power problem. I'd check the cable condition and connections. .... If you get the "click", then the starter relay is working properly. .... Can you turn the engine by hand or pushing the car? (to make sure it's not locked up.) In my city, I can take the car to a parts store with a diagnostic machine, and they will identify the problem.
