TwinTurbo.NET: Nissan 300ZX forum - Re: na to TT swap
Subject Re: na to TT swap
Posted by dzero196 on April 10, 2013 at 4:17 PM
  This message has been viewed 156 times.
In Reply To na to TT swap posted by jhop1988 on April 08, 2013 at 11:21 PM
Message 1st check the fuel pressure.
2ed check your piping make sure you have no boost leaks and make sure they are going the right directions..( happend to a buddy i know he accidentally flipped them) got the same result
what kind of inter coolers do you have?
3ed run your codes if you dont have any codes its not the maf
(if you run the car with no maf you should be able to get up 2 3k)
4th check your compression!!!!!!
