TwinTurbo.NET: Nissan 300ZX forum - Considered it..
Subject Considered it..
Posted by Cjw3 on April 08, 2013 at 5:56 PM
  This message has been viewed 263 times.
In Reply To What is the condition of the inner and outer joints on>>> posted by ZUL8TR on April 08, 2013 at 05:32 PM
Message Locktight is a good friend.. and for an 'Oh My God, Don't ever Move' type of fit it's great.. also considered making it a press fit.. Install would be difficult for something as thin as this ring.. Don't think I need to get that crazy.. it's only a spacer ring to seal aginst.. The Casket Maker RTV has worked well in the past for 'Minor no Movement' type of Installs.. and this had about .001-.0015 inch clearance.. just tight enough to make it go on when started straight.
No noticeable Play in the Joints.. Still wonder what the cause is.. guess it's not a very common problem, as no one has an answer yet for it..
From what I have found, the TT and the NA use the Same seal in suspension piece ( as per Z1 ).. so that rules out the NA Vs TT thing.. wonder if it's a Z31 VS Z32 Axle Piece?.. I'll keep hunting
Cj
