TwinTurbo.NET: Nissan 300ZX forum - Once you remove the caps, Timing sprockets
Subject Once you remove the caps, Timing sprockets
Posted by scottmt21 on April 08, 2013 at 12:24 AM
  This message has been viewed 207 times.
In Reply To Re: Great points, I sprayed the cams and caps with...... posted by 1995z32tt on April 07, 2013 at 06:37 PM
Message and the VTC actuators the cams will come out straight up. One cap on each cam is bigger then the rest. Start with that cap first. If it is stamped I1 or E1 then the nest one to it would be I2 or E2 Etc. If it is stamped I5 or E5 then the next one should be I4 or E4 etc.... In other words keep them in numerical order 12345 or 54321..
