TwinTurbo.NET: Nissan 300ZX forum - ok make sure:
Subject ok make sure:
Posted by Zvil (FL) on April 07, 2013 at 8:22 AM
  This message has been viewed 210 times.
In Reply To Re: twin turboswap posted by jdavey11 on April 07, 2013 at 08:04 AM
Message You have a good battery
Your contacts on the battery terminals are clean
Your starter wire is healthy
Your contact on your engine block ground is connected
You have it in Neutral
You aren't shorting ANYWHERE (check to see if the wire connecting the solenoid to the starter motor isn't shorting out on the heat shield
You can spin the motor an entire revolution with a wrench.
If all these fail I would recommend getting a NEW starter.
*disclaimer*: all that I say may be true or I may be completely wrong and I accept that.... please, it is your duty as another person on the internet to impolitely tell me how wrong I am :)
"The dreaded 2nd windshiled wiper swipe when you turn it off its almost like tis showing you that it's boss, and it doesn't have to stop when you tell it to :("-College Boy
(discussion on ptu relocation)
"No good reason to put it there anyway. -Bernie (NoVA)
False -vorpalZ
False. -Bernie (NoVA)
You're correct, there are 3 good reasons -vorpalZ
Wow, right again, just remembered another, make that 4 -vorpalZ"
XD
