TwinTurbo.NET: Nissan 300ZX forum - Great points, I sprayed the cams and caps with......
Subject Great points, I sprayed the cams and caps with......
Posted by ZaXxon on April 07, 2013 at 6:25 AM
  This message has been viewed 254 times.
In Reply To My caps were stamped posted by SammybTT(TN) on April 06, 2013 at 08:38 PM
Message Royal Purple Maxfilm penetrant and wrapped them in parchment paper for storing. I then placed the wrapped cams in foam piping insulation to protect them while stored.
Any rust that may form on the bearing or lobe surfaces can be addressed with 00 or 0000 steel wool.
I also used the steel wool on the bearing surfaces of the heads and cam caps to debur them before assembly.
If removing your lifters, store them submerged in oil.
