TwinTurbo.NET: Nissan 300ZX forum - Yea, I know it doesn't seem right, but all I can say is that
Subject Yea, I know it doesn't seem right, but all I can say is that
Posted by Gordo 93TT Daytona on April 06, 2013 at 7:27 PM
  This message has been viewed 462 times.
In Reply To So the extra .2" drop required .3" of camber correction? posted by ZXoltan on April 06, 2013 at 04:58 AM
Message for a drop of about one inch, or maybe just a little more...I needed 0.60" of shim; or double the shim height used to compensate for the Eibachs which is generally considered to be 0.80". Remember the 0.80 drop of Eibach is based on a new springs, so there would be additional drop as it ages; and the NA springs I took off were also sagging a little from age. Also the rubber compresses. So overall, I may have a drop significantly more than a new set of Eibachs.
I think if someone wanted to use these shims, they should either do what I did, and use an adjustable UCA to mock up the shim thickness required... OR fab shims w/open slots so they could be dropped in from the top. This would allow the alignment shop to set up the camber adjustment w/o removing the UCA bracket.
_________________________________________________
