TwinTurbo.NET: Nissan 300ZX forum - cam removal
cam removal
1995z32tt
on April 06, 2013 at 12:02 PM
hey guys getting ready to remove my cams. cam caps are off just was wondering if someone could help me out seeing i never remvoed the cams before any help would be great thanks
cam removal -
1995z32tt
12:02:40 04/06/13
Re: cam removal
1995z32tt
12:03:50 04/06/13
Make sure you keep the caps in the same order they came off
Broke_as_****
12:23:01 04/06/13
Re: Make sure you keep the caps in the same order they came off
1995z32tt
12:25:20 04/06/13
The caps are not labeled. You need to use punches to label
ZaXxon
16:48:31 04/06/13
FSM = Factory Service Manual; caps are not labled but
Gordo 93TT Daytona
19:50:48 04/06/13
+1.... if you already removed them without marking location
Zvil (FL)
22:27:15 04/06/13
my caps were not stamped. Learned this the hard way (n/m)
wickdGSXR
12:30:11 04/07/13
My caps were stamped
SammybTT(TN)
20:38:55 04/06/13
Great points, I sprayed the cams and caps with......
ZaXxon
06:25:47 04/07/13
Re: Great points, I sprayed the cams and caps with......
1995z32tt
18:37:39 04/07/13
Once you remove the caps, Timing sprockets
scottmt21
00:24:11 04/08/13
What is parchment paper? Like wax paper?? (n/m)
ZXoltan
13:37:31 04/08/13
Yes (n/m)
ZaXxon
17:28:45 04/08/13
Wierd thing with my motor when the caps were inspected:
Jkova300z
14:24:23 04/08/13
Possible they were numbered incorrectly for some reason
ZXoltan
16:12:01 04/08/13
