TwinTurbo.NET: Nissan 300ZX forum - The ECU Controls the Car..
Subject The ECU Controls the Car..
Posted by Cjw3 on April 06, 2013 at 10:05 AM
  This message has been viewed 166 times.
In Reply To Can I use an NA ECM with a TT chip? posted by Barry(TN) on April 06, 2013 at 08:18 AM
Message From reading your post, you still have all the TT Goodies the TT ECU needs to control, the NA ECU will not control them.. the Big problem is the TT Fuel Controller, you have a 3 Speed in the Car, the ECU is looking for a 2 Speed.. the Result ( as I have read.. never done it myself ) is the TT Fuel Controller will shift 'off' momentarily while accelerating , and the Car will stumble when this happens..
The Boost sols and fan stuff can be controlled by other means.. if you must use the Wrong ECU
If I read between the lines of your first post properly, I think you need a TT ECU..
Cj
