TwinTurbo.NET: Nissan 300ZX forum - I did something similar when I added extra 300Degree shims.
Subject I did something similar when I added extra 300Degree shims.
Posted by Gordo 93TT Daytona on April 05, 2013 at 11:13 AM
  This message has been viewed 795 times.
In Reply To Has anyone worked out the change in camber angle .. posted by DaZedMan on April 02, 2013 at 02:24 PM
Message The 300 Degree kit is design to compensate the Eibach 0.8" drop with 0.30" shims. My correction factor required 0.60 to 0.70 worth of shims which I fabricated. The drop measured at the wheel arch to wheel center was a little over an inch.
I used an adjustable aftermarket UCA to determine how much we needed to push out the uprights, e.g., the extension of the UCA, for proper negative camber. That distance was then applied to the 300 Degree Kit by adding extra shims (totaling about 0.60 inches).
The full thread click here: 300 Degree Camber Kit modification needed for camber setting
_________________________________________________
