TwinTurbo.NET: Nissan 300ZX forum - Removing stuck idler studs?
Subject Removing stuck idler studs?
Posted by evan_aggie on April 04, 2013 at 10:54 PM
  This message has been viewed 246 times.
Message I was attempting to replace the idler studs with RameyZ per recommendations from folks here after my timing belt skipped a few teeth.
Anyway, I've got a stud remover, and attempted to take it out, but it wasn't budging and I started to worry about snapping it off. I had a 16" breaker bar and couldn't get it to turn.
I sprayed with a little pb blaster. Anyone have another idea? I thought about using a little torch, but there is some rubber foam/seal around the back timing cover.
