TwinTurbo.NET: Nissan 300ZX forum - Equus Electric Water Temp Gauge
Subject Equus Electric Water Temp Gauge
Posted by Koppz32 on April 04, 2013 at 9:07 PM
  This message has been viewed 241 times.
Message Hey guys, i recently bought a equus electric water temp gauge. The problem is, is that the gauge reads full when the ignition is in the ON position, or when it is running it still reads full. I hooked the positive of the gauge to a switched +12V, hooked the ground to a chassis ground. The "S" sensor i soldered a wire to the pin, snaked the wire to the radiator pipe, i had to tap the pipe, i T'd the orginal sender wires to it, and also the new equus sender, i placed a spade on the end and nutted it down so it wouldn't come loose. Sorry, this sounds hard to understand. But if you want, please email me at tkscarface0@gmail.com , for pictures of what i did. Thanks guys!
