TwinTurbo.NET: Nissan 300ZX forum - If it needs a grind, just go with a good condition original
Subject If it needs a grind, just go with a good condition original
Posted by ZinnZ32 on April 03, 2013 at 12:19 PM
  This message has been viewed 297 times.
In Reply To Curious if a crank is salvageable posted by BlackholeZ on April 02, 2013 at 11:39 AM
Message You can polish an original Nitrided Crank and still retain the integrity of the nitride layer, as the coating penetrates into the metal a bit.
VG's need to be built with a 'solid foundation', ie: a nice bottom end with a good, straight, original nitrided, and polished crank. Make sure your main, and rod clearances are consistent as possible, a little looser is even ok for big power. Use patience with plasti-gauges, as they take a bit of time to get the hang of using effectively. You need every bit of precision you can get out of a home garage/plastigauge measurement technique, as new power thresholds with bigger turbos and breather mods put a lot of strain on the bearings!
__________
Version 3.01
