TwinTurbo.NET: Nissan 300ZX forum - Re: Curious if a crank is salvageable
Subject Re: Curious if a crank is salvageable
Posted by Tech@EPR on April 02, 2013 at 7:55 PM
  This message has been viewed 344 times.
In Reply To Curious if a crank is salvageable posted by BlackholeZ on April 02, 2013 at 11:39 AM
Message a good polishing will do wonders to a journal that would "appear" damaged. Have the journals measured and cleaned..I'd have the crank mag checked as well just to cover your bases. Then have it micro polished. Once thats done and everything checks out you should be good to go.
Reconditioned cranks are ok as well just so long as they have dimensions of the standard journal sizes and are properly heat treated again to maintain case harden depth and durability.
Ep Racing | Create Your Badge
