TwinTurbo.NET: Nissan 300ZX forum - KYB AGX shocks with stock NA springs
Subject KYB AGX shocks with stock NA springs
Posted by DaZedMan on April 02, 2013 at 2:19 PM
  This message has been viewed 708 times.
In Reply To What are your coilovers set to? Stock height? posted by Woody75 (Denver) on April 02, 2013 at 09:37 AM
Message this is my daily driver, 1993 NA.
The alignment analysis said the car was "lowered," from which I assume some spring sag after 100,000 miles. Camber was the same on both sides (-1.9 if I recall correctly) so if it is sag, it is equal on both sides. I was asking mostly to try to determine, without taking the whole front end apart, whether it was sag, which i could correct with the camber kit, or bushing failure, whihc would require new bushings or arms.
