TwinTurbo.NET: Nissan 300ZX forum - Front upper control arms are pretty robust. Failure is not
Subject Front upper control arms are pretty robust. Failure is not
Posted by Gordo 93TT Daytona on April 02, 2013 at 10:51 AM
  This message has been viewed 643 times.
In Reply To upper control arm bushing replacement? posted by DaZedMan on April 01, 2013 at 08:33 PM
Message common. If yours have deteriorated bushings, good used replacements are readily available cheap and are standard sized, meaning if you replace one OEM w/ another, you will not need another alignment (unless of course other changes have been made.) Also you might consider making up some extra shims to get the 300 Degree camber correction exact. The kit is designed to correct a 0.8" spring drop (sag). If your drop is more, then you'll need more. YOur alignment specialist can add a few thick washers to the mix, but homemade shims would be a better fix.
_________________________________________________
