TwinTurbo.NET: Nissan 300ZX forum - upper control arm bushing replacement?
Subject upper control arm bushing replacement?
Posted by DaZedMan on April 01, 2013 at 8:33 PM
  This message has been viewed 935 times.
Message Just got a new set of tires and had alignment checked. old tires had wear on inner edges. Alignment check said it is from a combination of too much negative camber and toe-out.
Looking to get 300degree camber kit, but was wondering if upper control arm bushings typically go bad, like most of the other suspension bushings, and if there is a preferred replacement. Haven't seen a listing for ES replacements.
Thanks
