TwinTurbo.NET: Nissan 300ZX forum - Sounds about right.
Subject Sounds about right.
Posted by PiotrC70 on March 31, 2013 at 7:33 PM
  This message has been viewed 236 times.
In Reply To Low oil pressure at warm idle-Common areas for oil leaks? posted by 280ZuL8R on March 31, 2013 at 07:12 PM
Message Depending on how cold it is during startup, and oil type, you can have startup be ~100psi. After it gets up to temp, having it near the 1st hash mark on the oil pressure gauge should be around your 35psi mark. At cruising speed, 60 is also about right.
Did you notice a change or are you being paranoid?
As for the common areas of oil leaks.
Rear main
Valve covers
exhaust valve cover 1/2 moon
1993 TT. R.I.P. 09.15.2010
