TwinTurbo.NET: Nissan 300ZX forum - I would suggest you make up a plug wire extension
Subject I would suggest you make up a plug wire extension
Posted by ttsmokin on March 31, 2013 at 5:15 PM
  This message has been viewed 258 times.
In Reply To Occasional miss and moving timing. posted by PiotrC70 on March 31, 2013 at 02:19 PM
Message and use it on the #1 cylinder between the coil pack + plug. This will 100% make sure we are not looking at a timing reading error.
Where is your CAS currently located (middle, off to one side etc)?
I would remove the CAS and check the gear and metal tab for wear.
What does Datascan list as the idle timing? It should list 15*. Is it seeing neutral "on" and idle switch "on"?
