TwinTurbo.NET: Nissan 300ZX forum - After the build, I didn't have any luck with the #1 coil.
Subject After the build, I didn't have any luck with the #1 coil.
Posted by PiotrC70 on March 31, 2013 at 4:03 PM
  This message has been viewed 241 times.
In Reply To Have you tried checking timing using different methods? posted by Evan_Wright (Ca) on March 31, 2013 at 03:01 PM
Message The gun was picking up intermittent pulses and as a result, I got intermittent lights with the gun. I still use the PTU loop as that has worked best for me and get a light from the timing gun every time. For grins, I will also remove the PTU and check continuity per the FSM.
To clarify in case it was misunderstood. The timing is dead on and not bouncing at idle. The timing flat out moved AFTER the drive and sometime in the last 8-9 months since my build was completed.
1993 TT. R.I.P. 09.15.2010
