TwinTurbo.NET: Nissan 300ZX forum - I'd start by checking the battery....
Subject I'd start by checking the battery....
Posted by Medallion Man on March 29, 2013 at 2:37 PM
  This message has been viewed 164 times.
In Reply To Your fuel system might be losing pressure while it sits. posted by zellamay on March 29, 2013 at 12:41 PM
Message do a check on the connectors, clean them, check the earths on the block.
check the battery voltage (go to an auto electrician).
how old is the battery?
if that seems OK do a full check and clean of all the connector, MAF, PTU, TPS, CAS, coil packs, injectors... etc..
then if still having issues check out the 6 P's (search in tech)..
best of luck.
if it is an issue with injectors and or a fuel leak you should smell fuel. (the 6 P's covers that... I think)
