TwinTurbo.NET: Nissan 300ZX forum - Bad temp sensor (or broken wire - common) could
jzack
on March 27, 2013 at 6:29 PM
My '91 NA starts up and then just dies when you don't press
posted by NismoDHS
on March 27, 2013 at 05:17 PM
cause the ECU to sense the wrong condition of the car. What led up to this issue - just started happening or started after work was done on the car/engine?
NismoDHS
17:17:45 03/27/13
Bad temp sensor (or broken wire - common) could -
jzack
18:29:12 03/27/13
when u step on the gas your opening the throttle bodies and
white22sky
18:31:39 03/27/13
What's crazy is that the car has been running great since I
NismoDHS
18:47:06 03/27/13
Problem Solved!! (sort of)
NismoDHS
22:03:38 03/27/13
Your chest huh... must have a huge rack;) (n/m)
white22sky
22:28:33 03/27/13
Your codes will not disappear instantly.
Summeronthechain (MN)
07:19:37 03/28/13
Idle circuit is very, very sensitive...
OverZealous (CT)
18:18:12 03/28/13
