TwinTurbo.NET: Nissan 300ZX forum - If the trans switch is a ground there will be only
Subject If the trans switch is a ground there will be only
Posted by JMartz on March 27, 2013 at 2:58 PM
  This message has been viewed 192 times.
In Reply To I am guessing there may be a stray wire/connector posted by ZinnZ32 on March 26, 2013 at 04:18 PM
Message one wire going to it. Go find power at the lights themselves. If none, then fuse. A test I sometimes use (but you must be certain of the circuit's configuration) is to power the device that the car controls by grounding. It has to work with a new grounding switch is wiring is intact.
