TwinTurbo.NET: Nissan 300ZX forum - 10mm bit to remove the head studs?
nemo1080 (Iowa)
on March 27, 2013 at 2:37 PM
Definitely bent rod, used a thin rod to compare the height
posted by SMAZ (OKC)
on March 25, 2013 at 12:20 AM
shouldn't you be using a 12 point socket on the nut at the top of the head studs? or did you mean head bolts??
How to repair bent rod #6 from fuel hydrolock?
SMAZ (OKC)
00:44:05 03/21/13
How do you know the rod is bent if you havent taken it apart
Woody75 (Denver)
09:45:08 03/21/13
Not positive, but best guess since they pulled 3-4 ounces
SMAZ (OKC)
10:01:32 03/21/13
I'm assuming this is the Z Shane called me on last night.
Woody75 (Denver)
10:55:32 03/21/13
No compression numbers from before, but the noise
SMAZ (OKC)
11:08:53 03/21/13
I agree on the noise.
Woody75 (Denver)
11:13:43 03/21/13
Me too. I mentioned it may have had issue before since it
SMAZ (OKC)
11:45:50 03/21/13
SMAZ (OKC)
00:20:25 03/25/13
10mm bit to remove the head studs? -
nemo1080 (Iowa)
14:37:19 03/27/13
