TwinTurbo.NET: Nissan 300ZX forum - Timing is at 35'-40' almost right off idle when engine
Subject Timing is at 35'-40' almost right off idle when engine
Posted by Gordo 93TT Daytona on March 26, 2013 at 9:09 PM
  This message has been viewed 261 times.
In Reply To 35 degree timing?? Lies! posted by dvice on March 26, 2013 at 05:30 PM
Message load is not severe. It stays in that range even at high rpms until you finally begin to get to the zone where the engine comes on boost. So the fact that you are running 35' w/o issue is not surprising.
As you note, however, it is surprising that the CAS is so far off center. I agree w/ TTSmokin, to be certain of actual timing get your read off an ignition extension wire between the plug and coil.
_________________________________________________
