TwinTurbo.NET: Nissan 300ZX forum - What is a CTV?
Subject What is a CTV?
Posted by ttsmokin on March 25, 2013 at 8:15 PM
  This message has been viewed 227 times.
In Reply To ?, i have a jwt programmed ecu & 535 turdbowls ... and posted by genic on March 25, 2013 at 08:03 PM
Message 1) Depends on what the wastegates are set to on 535 turbos. I am fairly certain they should be set to around the 12psi mark, you might see a couple psi less on the actual car. You might have a boost leak.
2) Every set up is different, some cars can knock at 13psi on 93 octane (local guy for example). Others won't until 20. I wouldn't run more than 16psi of boost.
Reference this post: http://twinturbo.net/nissan/300zx/forums/general/view/2470762/Octane-Vs-Boost.html
Perhaps you mean VTC solenoids, not CTV?
You have 0 tune-ability with JWT ecu, it's a burned chip. You can't do anything with it.
