TwinTurbo.NET: Nissan 300ZX forum - ?, i have a jwt programmed ecu & 535 turdbowls ... and
Subject ?, i have a jwt programmed ecu & 535 turdbowls ... and
Posted by genic on March 25, 2013 at 8:03 PM
  This message has been viewed 299 times.
Message i dont have a boost controller setup on them yet, and i get 8psi tops (which pulls like a train btw). here are a couple questions i do have.
1) is that a normal psi on the stock wastegate(s)?
2 parter) i have a IPP built motor (stage 5, without cams)...what would be a safe top psi to run on 93 octane (15-18psi?), and how high on scramble boost (21psi?)?
i need to replace my worn CTV's ...is there a good write-up on replacing those? should i replace my cams since i will have the heads open anywise? if i DO replace my cams ...what would be a good cam setup for these turbos and my engine? ...keep in mind that i will have full 2.5' pipes to the turdbowls and tb's soon.
i forgot what other questions i had, but if i remember i will ask in this thread.
psi, the new greddy profec boost controller is f-ing titties on a stick! its so TINY, but so awesomeness.
this setup should make for a pretty fun ass street car.
