TwinTurbo.NET: Nissan 300ZX forum - Not real common unless perhaps oil fouled or someone
jzack
on March 25, 2013 at 6:19 PM
How common is it for a O2 sensor to fail? (n/m)
posted by 1badttz
on March 25, 2013 at 05:18 PM
used O2 damaging (silicone) RTV as sealant somewhere in the intake air stream track? Now if the O2 sensor is original to the car -- that is possible too. They only last so long....
1badttz
17:18:51 03/25/13
They are a wear item, depends on exhaust temp, fuel used etc
ttsmokin
18:11:11 03/25/13
Not real common unless perhaps oil fouled or someone -
jzack
18:19:30 03/25/13
Every 50-75k they should be replaced
Summeronthechain (MN)
22:02:39 03/25/13
When they fail do they still pass the self test in the FSM? (n/m)
SMAZ (OKC)
08:51:28 03/26/13
If they fail a code will show. If the heater section fails >
ZUL8TR
14:05:26 03/26/13
I'm getting a code 33
1badttz
11:03:39 03/26/13
When you say it goes away for a day or two....
300ZMang
08:23:24 03/28/13
Oh.... and it's not weird that it only does this when warm
300ZMang
08:24:49 03/28/13
