TwinTurbo.NET: Nissan 300ZX forum - Re: wiseco ring gap
Subject Re: wiseco ring gap
Posted by Tech@EPR on March 25, 2013 at 2:07 AM
  This message has been viewed 534 times.
In Reply To wiseco ring gap posted by sonazty on March 24, 2013 at 10:36 PM
Message That spec sheet is very vague and should not be referenced for ring gap. If you plan to run 20psi Id suggest a. 018-.022 for the top and a. 024-.026 for the second ring. With boost you always have to account for increased heat and expansion rates. Last thing you want is to get ring flutter or burn the seal because you have too much pressure on the rings and not enough gap to relieve the ring. Each engine is different and gaps should set according to the users power and intended use of their engine.
Ep Racing | Create Your Badge
