TwinTurbo.NET: Nissan 300ZX forum - Definitely bent rod, used a thin rod to compare the height
Subject Definitely bent rod, used a thin rod to compare the height
Posted by SMAZ (OKC) on March 25, 2013 at 12:20 AM
  This message has been viewed 133 times.
In Reply To How to repair bent rod #6 from fuel hydrolock? posted by SMAZ (OKC) on March 21, 2013 at 12:44 AM
Message as the piston came up compared to the one next to it at TDC. Oil pan is off, ALMOST have the head off, but broke the 10mm bit trying to remove the head studs. One came slightly loose then second one broke the bit. So far diagnosis is consistent and plan is to check bearings, crank shaft on #6. If all good, hone cylinder, replace rod, rings and piston and go back together. Going to get bigger tools tomorrow.
1996 TT #61 of 300
