TwinTurbo.NET: Nissan 300ZX forum - Sounds like a bad connection somewhere...
Subject Sounds like a bad connection somewhere...
Posted by Jim (Selin Design) on March 23, 2013 at 6:00 PM
  This message has been viewed 204 times.
In Reply To Installed Selin and now won't idle posted by soon2boost on March 22, 2013 at 08:48 PM
Message Take a look at the condition of the male pins on the sensors and also the female pins on both translator leads. Use a probe to push on each female pin to be sure they stay put. If one of them moves back into the housing the retainer tab needs to be reset. I have a diagram that shows how to do so if that's the case. If all is good with the pins and the problem persists I'll get your a replacement out asap. Sorry for the hassle! Sometimes loose pins like this can make it through the QC process then be intermittent later. (each unit is interrogated digitally for proper operation, response, and accuracy)
www.selindesign.net
