TwinTurbo.NET: Nissan 300ZX forum - skipping T-belt will only advance the timing
Subject skipping T-belt will only advance the timing
Posted by Zvil (FL) on March 21, 2013 at 8:38 PM
  This message has been viewed 125 times.
In Reply To then timing belt jumps should always result in timing that posted by LJZTT on March 21, 2013 at 06:21 PM
Message If the belt skips on the camshaft with the CAS then the camshaft will stay still which would act like you turned the CAS CCW (advanced timing)
If the belt skips the crankshaft then all the camshafts will stay still which would also act like you turned the CAS CCW, this would also obviously cause hesitation.
*disclaimer*: all that I say may be true or I may be completely wrong and I accept that.... please, it is your duty as another person on the internet to impolitely tell me how wrong I am :)
"The dreaded 2nd windshiled wiper swipe when you turn it off its almost like tis showing you that it's boss, and it doesn't have to stop when you tell it to :("-College Boy
(discussion on ptu relocation)
"No good reason to put it there anyway. -Bernie (NoVA)
False -vorpalZ
False. -Bernie (NoVA)
You're correct, there are 3 good reasons -vorpalZ
Wow, right again, just remembered another, make that 4 -vorpalZ"
XD
