TwinTurbo.NET: Nissan 300ZX forum - I am aware of 5 causes to the timing drift
Subject I am aware of 5 causes to the timing drift
Posted by Zvil (FL) on March 21, 2013 at 1:34 PM
  This message has been viewed 181 times.
In Reply To explain how the timing belt can drift after a fresh 120k? posted by LJZTT on March 21, 2013 at 12:39 PM
Message 1) the tensioner failed/ was not set properly
2) the bearings on the timing pulleys or the studs which they are attached to failed and allowed the belt to lose tension (if you want peace of mind get these studs)
3) one or more of the camshafts jammed momentarily
4) the T-belt got soaked with oil or antifreeze and it became soft/stretched
5) if you run your timing belt without the covers, a rock or other road debris lodged itself between the gear and the belt and either stretched or jumped the T-belt
*disclaimer*: all that I say may be true or I may be completely wrong and I accept that.... please, it is your duty as another person on the internet to impolitely tell me how wrong I am :)
"The dreaded 2nd windshiled wiper swipe when you turn it off its almost like tis showing you that it's boss, and it doesn't have to stop when you tell it to :("-College Boy
(discussion on ptu relocation)
"No good reason to put it there anyway. -Bernie (NoVA)
False -vorpalZ
False. -Bernie (NoVA)
You're correct, there are 3 good reasons -vorpalZ
Wow, right again, just remembered another, make that 4 -vorpalZ"
XD
