TwinTurbo.NET: Nissan 300ZX forum - I tried hooking on with vice grips with no luck
Subject I tried hooking on with vice grips with no luck
Posted by ChrisMedaris on March 21, 2013 at 12:53 PM
  This message has been viewed 160 times.
In Reply To FML, intake camshaft dowel pin posted by gt300zxtt(HI) on March 21, 2013 at 04:10 AM
Message i ended up taking a metal saw and cutting off flush with the cam shaft, then took a drill bit slightly smaller in diameter and and proceeded to drill through the dowel pin. Then the sidewalls were so weak i was able to tap with flat head and pull pieces out. This was all down with the motor in the car, kind of a tight angle to get the drill in there though.
