TwinTurbo.NET: Nissan 300ZX forum - If turning on the a/c drops the idle
Subject If turning on the a/c drops the idle
Posted by SeanK (StL) on March 20, 2013 at 8:34 AM
  This message has been viewed 227 times.
In Reply To yes, the AAC is not at the desired AAC as in the table posted by Dane (Houston) on March 19, 2013 at 12:57 AM
Message is the FICD working? I think there's an ohm test for it in the FSM.
What does the AAC % do when the a/c turns on? If it goes up (above ), I may try setting the base idle to around 850-900 rpm. Using Datascan/Nistune, not the dash cluster.
It appears to be unsuccessfully trying to raise the idle with the AAC, and I'm wondering how it will react if you give it a larger base amount of air to work with...
