TwinTurbo.NET: Nissan 300ZX forum - All Marks are timed at TDC #1
Subject All Marks are timed at TDC #1
Posted by Cjw3 on March 19, 2013 at 9:04 AM
  This message has been viewed 113 times.
In Reply To The pulley TDC, not the gear. I thought back timing cover posted by evan_aggie on March 19, 2013 at 08:07 AM
Message With the Cams in the right spot, ALL the Cam Sprocket marks will line up with the backing plate marks, and the Crank should be at #1 TDC ( if you put the cover on ) or the Divit on the Crank sprocket( behind the washer and if the Sprocket was not put on backwards) will match the Casting Mark in the Oil Pump Housing Cover.. it's not a mistery.. just basic TDC Timing.. I've done one four cam motor type, where everything is timed at 30 deg BTDC.. you have to have a book for that SOB to find the marks..
Cj
