TwinTurbo.NET: Nissan 300ZX forum - I'm an OEM guy
I'm an OEM guy
Cjw3
on March 17, 2013 at 10:28 PM
Holy F. No clue what happened. BTW: Greddy Belt or OEM?
posted by evan_aggie
on March 17, 2013 at 04:45 PM
So I'm no help.. Check out the Gap on the tensioner.. looking like it's too loose, or lost it's tension adjust.. but to me it looks like the belt was running loose, and the slack was scratching against something.. Inside the bottom Cover?.
Cj
Timing Marks & Debug
evan_aggie
12:45:39 03/16/13
Always
Cjw3
15:33:43 03/16/13
strange that both are lined up except crank pulley (n/m)
evan_aggie
17:44:03 03/16/13
Re: strange that both are lined up except crank pulley
Cjw3
18:50:10 03/16/13
I'm about to pull the water pipes. I think I'm going smoked
evan_aggie
19:17:30 03/16/13
Not belt stress..
Cjw3
19:59:46 03/16/13
evan_aggie
16:45:34 03/17/13
I'm an OEM guy -
Cjw3
22:28:55 03/17/13
That gap looked like 4mm to me, *shrug*. I'll go OEM. (n/m)
evan_aggie
23:51:04 03/17/13
Replace the adjuster!
Cjw3
06:41:03 03/18/13
"Shock Absorber"? Isn't that just a heavy duty coil spring?
evan_aggie
08:13:28 03/18/13
Shock Absorber.. or something
Cjw3
13:34:52 03/18/13
BTW: Coz says that crank pulley mark won't line up.
evan_aggie
15:30:22 03/18/13
Actually, I think I disagree with Coz, but again, will check (n/m)
evan_aggie
16:09:14 03/18/13
The pulley or the gear mark? (n/m)
Woody75 (Denver)
19:58:03 03/18/13
The pulley TDC, not the gear. I thought back timing cover
evan_aggie
08:07:37 03/19/13
All Marks are timed at TDC #1
Cjw3
09:04:30 03/19/13
evan_aggie
10:15:17 03/19/13
The gear dots should match backing plate, belt lines wont (n/m)
ttsmokin
23:14:05 03/18/13
I used an OEM tining belt during my rebuild
SammybTT(TN)
13:49:23 03/18/13
FYI.. the backing plates are ajustable and can move..
Medallion Man
05:16:30 03/20/13
